Blacksunshine
- New Brunswick
Stock Conti sport contacts...We'll see what the stretch looks like if it's too extreme we'll just change out the rubber
Hey guys, so I ordered a set of spacers 15mm Rear 10mm Fronts over black Friday weekend assuming they'd go on my stock Austins but recently came across a local ad for Miro Type 111's at a great price
Wheel Specs: 18x8.5 +35ET
I am currently set up on BC Coilovers that are still set at factory specs (unadjusted)
Wondering if these wheels could be used with the spacers? My main concern is the offset. And also recommendations for tire size? Thanks!
Sent from my HTC One using Tapatalk
There is no way to know how a wheel fits if you only provide diameter and width. The offset aka backspacing also must be known. The offset lets you know how much it will poke out or tuck in from the fender.
You will be fine with either wheel and either tire size. Those sizes are not what I'd call aggressive, more normal sizes really. The post below has someone running 19x8.5 et43 with 235/35/19 tires on VWR springs and no extra rear camber, and he says he doesn't rub. When all other measurements are the same, an et42 wheel pokes outward 1mm more than an et43 wheel. That is a tiny amount so you shouldn't have a problem.
http://www.golfmk7.com/forums/showpost.php?p=209221&postcount=437
Wheel fitment question here from a new owner. I have some 18x9.5 +38 WedsSport SA-10Rs from my WRX. I've seen a few set ups from others running 9.5" wheels and was wondering if I could make these work with some wobble bolts? I know 9.5 is pushing it especially w/ the +38 offset, but if I could save myself some $$ and keep some great wheels that would be fantastic.
Stock ride height should fit, if you are lowered you might want to consider wheel spacers and rolling your fenders
Build thread: http://www.golfmk7.com/forums/showthread.php?t=13099
Awesome. Might order some wobble bolts this weekend then for a test fit. Now I'll just have to figure out what tire size I'll need (they currently have 245/40s) I'll eventually be adding some ST X coils and will check out spacers when I cross that bridge.
