So i have my 2019, just got it back after a month and kind of apprehensive about driving it now. I had the car for a week, then got a low oil pressure alert while the car still drove/ran. At stop, notice the car is throwing up...oil. i figured maybe a line came loose since the engine didn't seem to skip a beat. Come to find out, needed the whole engine and turbo replaced. "505 hole in block" fault code "p001100 camshaft bank1 timing over advanced" with metal in the oil, filter and pan. Found oil leaking at the back of the block.
I don't believe teardown of the original is done yet but noticed the work order mentioned camshaft error, and also that they topped it with 5w-40 oil instead of the 0w-20 i see had been initially recommended. Might this have some relation to the camshaft lockup scenario that seems to be floating around?
