Hello guys, I found this today:
SuperPro Alloy Wishbone Kit - MQB Platforms
http://www.superpro.com.au/tradevie...06k&view=part&id=ALOY0006K&cid=999501500&vid=
http://www.awesomegti.com/car/vw/golf-mk-7/superpro-alloy-wishbone-kit-mqb-platforms
Vehicle Application Information:
* VW Golf Mk7 (incl. GTI & R)
* Audi A3 8V
* Audi S3 8V
* SEAT Leon Mk3
* Skoda Octavia Mk3
Alloy Arm with DuroBall Rear Bushing with built in Caster and Camber Change- Exclusive to SuperPro:
* 1.5 to 2 Degrees Positive Caster Change per Side
* Up to 0.5 Degrees Negative Camber Change
* Alloy Lower Control Arm Assemblies eliminate unwanted flex
All Mk.VII Golfs incl. GTI and R use to come with cheap pressed steel front control arms.
They all share the same soft rubber bushings. Even more, for spirited driving or even
track use, the Golf suffers from insufficient front camber. Sadly there's no factory provided
way to adjust front camber (contrary to the rear).
Due to this sporty drivers want more camber. They also want stiffer bushings. This is
what you get with the SuperPro control arm kit.
Even more, these control arms are made from aluminium alloy instead of pressed steel,
just like the stock control arms of the Audi A3/S3 8V and new TT (Mk.III 8S gen).
The Superpro kit also comes with their innovative "DuroBall" bushing, which is both stiff
and has very low friction, similar to "Unibal" bearing used in racing, but with some amount
of damping.
Last not least, it does increase caster, which improves steering and straightline stability
and gives some dynamic camber gain on cornering.
I'm convinced it will provide great steering feel and handling, significiently reduced
understeer and higher lateral acceleration. That's what usually happens when you
add camber and caster and fit stiffer bushes.
As a bonus, these control arms are lighweight and corrosion resistant, while the stock
steel arms look rusty after just one winter. They also complement the alloy swivels
all Mk.VII GTIs and Rs come from factory with, and the alloy subframe I introduced here:
chassis & suspension tweaking - Audi A3 & TT parts
* Audi A3 8V
* Audi S3 8V
* SEAT Leon Mk3
* Skoda Octavia Mk3
of damping.
