chassis & suspension tweaking:
Audi A3 (8V) & TT (8S) parts using on Mk.VII Golf/GTI/R
important: I'm not responsible to any damage and consequences you make to your car.
Bear in mind, any changes to your car affect warranty. Even more, suspension is a a
major safety relevant part of the car. Do not do any changes if you're not 100 % sure to
do things right. Mistakes may cause serious accidents !!
Hello all,
Some of you who had a Mk.V or Mk.VI before might remember, I started similar threads on
the M.V and Mk.VI forums some years before.
intro:
For a reason. I did find out, that on the former "PQ35" platform (Mk.V/VI Golf/GTI/R/R32,
A3/S3/RS3 8P, TT/TTS/TT-RS 8J, Passat/CC 3C, Leon 1P, Tiguan, Octavia 1Z etc.) the very
most chassis and suspension parts have been interchangeable/compatible.
The point is, for performance reasons, it did make sense to fit front axle componentry like
Audi S3 and Passat or even Audi TT swivels + control arms to a Golf/GTI/R.
Contrary to the Golf variants, these swivels/hubs and control arms are made from forged
aluminium instead of steel, and there are some specific changes to geometry. Even more,
the S3 and TT control arms also came with solid rubber bushings, which are more reliable
and improve steering response.
For example, Audi S3 (= Passat) aluminium swivels, while shving some made compared to
the cast steel Golf ones, gave a slight change in steering ratio, lessening steering (angle)
effort. As mentioned, the stiffer and lighter alu control arms helped steering precision.
And the very biggest effect is gained by the use of Audi TT control arms, as they're slightly
longer and come with adjustable ball joint, giving camber adjustment. Remember, you
cannot adjust front axle camber on a stock Golf, and camber is of huge importance to
cornering performance. Any lack of front camber will cause understeer.
Well, why do I write this on a Mk.VII forum?
All the above similarly applies to the current "MQB" (Mk.VII) platform.
There are differences though. Firstly, most Mk.V/VI part do not fit to the Mk.VII.
I didn't try any yet though. Let's collect some facts (hope to be as correct as I'm able to
- remember, this is pioneer country).
Secondly, all Mk.VII GTI and R already come with aluminium swivels on front. Most likely,
also the GTD does. If in doubt, turn steering and have a look into your wheel well -
aluminium is silver, while the steel parts are painted black with some rust (after one salty
winter).
Next, all Golf/GTI/R and Audi A3 8V share the same sheet steel control arms, while both
the new Passat and the Audi TT come with aluminium control arms. The new Audi TT (8S
= 3rd gen) control arms again come with adjustable ball joints (same part numbers as
8J/2nd gen), so they're camber adjustable again.
As on the former PQ35 platform, rear axle parts are the same throughout several models.
No gain here. It's just Audi TT and Passat come with different rear aluminium hubs
for increased track width. Guess most of us don't want to pull rear fenders, so this
is no option.
However, there is one more thing worth looking on the MQB/Mk.VII.
While all the PQ35 Mk.V/VI variants came with a exceptionally solid and corrosion resistant
aluminium subframe, the use of this (expensive to manufacture) cast aluminium part on
the new MQB is limited to Passat, Audi A3/S3 and TT. Unfortunately, the Golf incl. GTI and R
just come with a cheaper sheet steel subframe, similar to the old Mk.IV. Obviously, it will
rust, as it's exposed to gravel, stones and salt, and not covered by plastic trim, as
most of the underbottom:
Fortunately, the Audi A3/S3 (8V) solid aluminium subframe seems to fit the Mk.VII Golf/GTI/R.
All other chassis parts share the same parts numbers. So I'd bet, it'll fit nicely.
This is the subframe's part number: [FONT="]5Q0 199 369 G[/FONT]
In Europe it's about 300 €, while ECS sell it for 393 $: http://www.ecstuning.com/ES2727346/
Just google the partnumber. http://oemwolf.com/oem-parts/5q0199369g.html
And it looks like this:
As I couldn't obtain any good photos of the A3 underbody, this is the way the aluminium
subframe looks on the former PQ35 (Mk.V/VI) platform (seems to be a Mk.V R32) with
heavy cast steel control arms, but neat subframe:
This is the 8V A3 quattro and S3 birdview; see alu subframe and steel control arms on the right:
Conclusion:
So, what to do now? When I have my Mk.VII GTI, I will most probably go for the mentioned
A3/S3 (8V) subframe and the Audi TT (8S) front control arms.
Subframe for beauty and reliability, control arms for beauty and camber. If I will be able to
get about -1°30' front camber with them, the increase in cornering performance will
be noticeable.
Needless to say, I'd be happy if someone will try it out as sonn as possible.
Hello all,
intro:
winter).
is no option.
Conclusion:
be noticeable.
