SugarMouth
- Nevada
Finally some info on the turbo inlets.
https://www.facebook.com/VolkswagenRacingUK/posts/1188806521227255
I guess the question now is, do the IS20 or IS38 need more air than the stock unit provides?
"We’ve seen some surprisingly significant power and torque increases from the fitment of the VWR High-Flow Turbo 90 as a result of the faster turbo spool and increased airflow it generates."
Why not provide them?
Fwiw so users understand the graph better, at 350cfm (where the blue line stops) that's basically stock levels. So even at stock levels, it's a pressure restriction of .75psi. At a stage 2 level, it's about 1.25psi. The higher the restriction causes an overall higher pressure ratio on the turbo. If we had a compressor map this would actually help, but at least on the IS20 and IS38, lower is better
