Alternating tail light signal? Vagcom tweak?
James75
Exeter
I'd like to see it when you've done it. I really like this, what about legality, is it legal?
James
sigi_dr
belgium
James
i'm sorry but i will have to wait untill tomorrow to try it, but i will surely post a video!
about legal issues, i think it's not legal nor illegal..
new top-class audi models have blinkers that 'move' from inside to out (like newer mustang models) so it's not illegal that blinkers do not light up at the same time, but it could create confusion with emergency lightbars found on towtruck's etc..
worst case scenario i will tell the cops that there must be an electronic malfunction and that i will take it to a dealer to check it out..
Grtz
Al_in_Philly
Philadelphia USA
I'm not sure if I'm thrilled with the look of having just the two turn signal units alternating, although I'm sure that this method will catch other motorists' eyes more quickly. If the car could utilize the full array of individual amber LEDs in both units switching on and off in sequence, I'd go for it in a minute. But absent of that option, I'm staying with the stock approach of both lighting units flashing in unison.
Finglonga
I wonder if that would pass the MOT?
sigi_dr
belgium
About the MOT inspection: questionable, certainly in Belgium.. but since you have a VCDS cable, why not change it right before you go to the MOT?
Here in Belgium, those things happen every year with almost every modified/tuned car.. wheels are swapped, lowering is either adjusted or replaced, ...
Video as promised:
https://youtu.be/RxbyckUkx-g
And in case you want the front unit to match your rear :D:
https://youtu.be/bmzfPJzqbOw
You can find the coding in the video description
PS: i'm not doing the front lights like in the video, i just wanted to show it ;)
Grtz
sigi_dr
belgium
Just looking at the video of the front, are the indicators on the mirrors not working or is it the camera angle?:confused:
Sorry for my late response, it is infact the camera angle ! (and bad timing, it was a sunny day at noon :p)
After a week of having this tweak active, i decided to change it, not to original but setting the OUTER blinkers to dunkelphase instead of the inner blinkers.
Here's why, each blink cycle goes like: Hellphase/Dunkelphase, so when you tap your blinker (presumed you have the original 3 cycle comfortblink) it does this:
Hellphase / Dunkelphase / Hellphase / Dunkelphase / Hellphase / Dunkelphase
which causes the following blinkers to light up:
Outer / Inner / Outer / Inner / Outer / Inner
some might find this confusing, that's why i'm changing it
I didn't make a video yet, but i changed it to do the opposite, so the outside blinker blinks last (inner/outer/inner/outer/inner/outer)
This also means the outside blinker doesn't blink at the same time with the front and mirror blinkers, but i tested this and i think nobody will notice, unless you tell them..
just to be clear:
Code:
STG 09:	(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16			Blinken links Hellphase
STG 09:	(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17		Blinken rechts Hellphase
STG 09:	(4)-Leuchte18BLK HLA60-Lichtfunktion A 18				Blinken links Dunkelphase
STG 09:	(4)-Leuchte19BLK HRC31-Lichtfunktion A 19				Blinken rechts Dunkelphase
Grtz
Finglonga
Doh! I can just see it blinking on full screen HD. I like the front and rears like that and will be getting them done a week Monday at a local VW specialist as I don't have a cable. Will look at your video when you put it up to try to deicide the way to have it lighting up first. Getting a few more tweaks done as well while there.
I asked them about the MOT in the UK and it should pass but he can change it back to stock if not.
vegasgolds
Henderson, NV
Grtz
so... are you going to make a new video but start it before you do the 3 blink action so we can see?
BTW, I'm glad the R has this cause I loved it on my Evo X MR (the 3 blink thingy)
