Just looking at the video of the front, are the indicators on the mirrors not working or is it the camera angle?
Sorry for my late response, it is infact the camera angle ! (and bad timing, it was a sunny day at noon
After a week of having this tweak active, i decided to change it, not to original but setting the OUTER blinkers to dunkelphase instead of the inner blinkers.
Here's why, each blink cycle goes like: Hellphase/Dunkelphase, so when you tap your blinker (presumed you have the original 3 cycle comfortblink) it does this:
Hellphase / Dunkelphase / Hellphase / Dunkelphase / Hellphase / Dunkelphase
which causes the following blinkers to light up:
Outer / Inner / Outer / Inner / Outer / Inner
some might find this confusing, that's why i'm changing it
I didn't make a video yet, but i changed it to do the opposite, so the outside blinker blinks last (inner/outer/inner/outer/inner/outer)
This also means the outside blinker doesn't blink at the same time with the front and mirror blinkers, but i tested this and i think nobody will notice, unless you tell them..
just to be clear:
Code:
STG 09: (4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Blinken links Hellphase
STG 09: (4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Blinken rechts Hellphase
STG 09: (4)-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Dunkelphase
STG 09: (4)-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Dunkelphase
Grtz
