Blind Spot Side Mirror Blue Tint
Over a year ago I purchased a set of blind spot side mirrors with blue tint from ECS Tuning. Took a while to get comfortable with them but now could not do without. The blue color seemed dark at first but now I do not notice as much.
Over the winter I could see my left side mirror starting to have issues. Looked dirty at first but then you could see the mirror backing was coming off the edge.
The driver side had no issues.
A replacement for the left side from ECS in same color would be $53.
A set is $99.95. I thought why spend that much if it will only last over a year.
ECS also sells OE style for $144 a set.
I knew Aliexpress sells them for much less so for $13.26 (A SET).
Blind spot mirror and blue tint. So why not try them.
Currently passenger side must be sold out but driver side is below.
Look what I found on AliExpress
https://www.aliexpress.com/item/32832626931/32832626931.html
Parts arrived. Well packaged.
Compared ECS and Aliexpress.
They are identical down to all molding marks.
Blue tint is the same. Only item I noticed was the Aliexpress part has Hungary name removed. On one side you can see part of the H so you know not made in China. The other you can make out the entire word Hungary.
Removed old and put new one on. Will keep new driver side as spare for now. No need to change as they are same part. All work but have not checked heated part. Not cold today.
Why did mirror fail? The mirror back has the reflective coating and then a black sticky film on top. The plastic back cram is then stuck to this black film. Over time the plastic frame pulled away from the mirror due to heat and cold plus the curved shape of the glass.
So for $14 I get a complete set.
I am all for buying in USA but how can one when ECS sells for $100 and Aliexpress sells for $14 and they are same part? Overhead? ECS could order from Aliexpress and sell the set for $50 and still be on top.
I know the China government likely helps it industry more than USA, right or wrong. Such a difference in price.
So Aliexpress and option when part is in stock.
