George Smooth
- South Africa
Updated: 6.04.2016
MAC SOFTWARE IN ITS CURRENT REVISION SEEMS TO HAVE CAUSED A ISSUE WHICH REVERTS THE BOX TO MAP 0 WHEN MAP CHANGES SO ITS ADVISED NOT BE USED AT THIS STAGE, LINK HAS BEEN TAKEN DOWN AND WILL BE PUT BACK UP ONCE WE RESOLVE THE ISSUE
11.11.2015
First available firmware update resolving idle issues some vehicles have had available here: http://www.n54tech.com/forums/showthread.php?t=34711
Please note when doing a firmware update JB unit must be connected to car and key in the on position.
We have finally reached a point where we have released our JB Stage 1 offering.
The unit is called a stage 1 or JB1 as it is called on the VW forums because it is a simpler unit compared to the yet to be released JB4 and does not signify stage tuning as one is use to when it comes to flash tuning.
This thread applies to the high output EA888 Gen 3 motor as found in the Golf 7 R, Audi S3 and Cupra 280hp. The unit is compatible to all market be it NA, Euro or Australia.
These units are now available and a ready for order at http://burgertuning.com/vw_volkswagen_Group1_JB1_tuner.html
The JB1 is a true plug and play tune offering safe and adjustable gains. It can be installed and removed in minutes.
Install instructions can be found here: http://burgertuning.com/instructions/S1_VAG_EA888_G3.pdf
The unit ships with a base setting in map 1 that increases the boost by +4.75psi over stock that is safe to be used with 91US octane and 95 Euro. The typical power gains on this setting are 35whp and 40ft lb. With higher octane accompanied with bolt ons and octane we have seen gains of 75whp and 70ft lb in Map 1. All of this whilst keeping the engines stock fail safes in place.
User interface software:
For users that have opted to purchase the optional BMS Data Cable you will need to download and install the user interface at this link http://www.n54tech.com/flash_files/jb4_interface.zip . The software is only compatible with Windows so for Mac a Virtual machine needs to be used.
Directions on how to connect, log and do firmware updates:
Directions on installing the interface and connecting to your JB can be found here
http://www.n54tech.com/forums/showpost.php?p=197021&postcount=1
In order to change the map in the picture below under the logging tab you can pick the required map. Select the map and click add.
Mapping
Upon shipping the following maps are active:
Map 0: Stock with complete pass through i.e. the JB1 does nothing
Map 1: Less aggressive boost profile map, this supports 91 octane at the base boost setting as well as bolt ons. If higher octane is used the boost can be increased as well as with bolt ons. We found that with intake, dp and 93 the boost can be pushed to +5.5psi yielding gains as seen in the following dyno graph. The method of doing this is in the second picture below. A E35 ethanol mix has been tested with this map and its fully compatible to run at boost levels up to +6.5psi when complimented with FBO (full bolt on mods). For anything higher than +5.5psi race fuel is required.
Map 3: Map three allows the JB1 to be the methanol controller working as a fail safe cutting boost if lack of meth flow is detected. You will require a Coolingmist FSB and a BMS Methanol kit to get this working. Please email info@ea888tech.com for meth support and the firmware required.
Map 1 Boost settings
Below is a diagram of where the user adjustment is made for boost over stock. Add in the value and click save.
There is a new released of the interface so now the boost setting change is under Boost Safety as circled in red.
Map 6 boost selection:
For map 6 you will need to connect to the unit and select map 6. If you have previously purchased your unit before reading this please email me george@burgertuning.com to receive a copy of the firmware.
Below is where you enter the values for map 6. It works similar to map 1 so the value is the additional boost over stock.
Dedicated Map 6 discussion thread here: http://www.golfmk7.com/forums/showthread.php?t=12325
The below maps are being tested over a greater pool of cars due to them being more aggressive. They will be released with a firmware update that you can load with your data cable at no extra cost.
Map 4: This map can be considered a low torque map suitable for circuit use and want something more conservative.
The unit can log boost on the two sensors, dme boost as well as the rail pressure. The balance of the engine parameters and settings in the picture are exclusive to the yet to be released JB4 but it gives you a idea of what is to come.
Support queries can be here on the BMS support forum http://www.n54tech.com or using email at george@burgertuning.com .
11.11.2015
Mapping
