where does this plug go ?
jalalor
PDX
While cleaning my car I found this plug on the driver's side floor mat. For the life of me I can't figure out where it came from. Ideas ?
cheers!
SRGTD
UK
Does it have a part no. on the reverse? I found a ‘plastic part’ under the driver’s seat the first time I cleaned my car and it had a part number stamped on the reverse. It was very small, so I had to use a magnifying glass to read it, but google-ing the number identified what the part was.
jalalor
PDX
Not much of a part number on the back side. Makes me wonder if this is even a VW part.
The Fed
Old Guys Rule
Florida
I can't identify it, but not every part has a part number. Look under the seat and under the dash. If you don't see where it could go, throw it in the glove compartment, just in case.
crxgator
Raleigh, NC
All the MQBs
It holds the carpet down. Remove your floor mat, and there should be a screw popping out under the dash along the floor.
jalalor
PDX
crxgator for the win!!!!
you are 100% correct, it was holding the carpet right behind the brake pedal. I was able to put it back in it's place. If it falls out again, I might put a bit of glue on it so it stays more firmly...
IllinoisGTIGuy
I found the same fastener in the spare tire well. Anyone know another location for these other than behind the brake pedal?
Sent from my Pixel XL using Tapatalk
Wrath And Tears
Azusa, CA
17 Sport, 99 E36
They are used to hold down the interior carpet as well as some trim pieces across the entire car. Since you found it in the back, I would start looking around there.
