Wheel tread wearing
mawallace
UK
While checking my depths this morning I noticed that my rear tyres had 5mm of depth and the "inside" tread, while the 'outside' tread was 2.4m.
both of them have worn in the same way - is this normal? do I need to have my wheel alignment checked.
The tyres are The Pirelli Cinturato P7's.
See photo
TecklenburgVW
Saint Cloud, FL
See photo
Yes, have the alignment checked. It appears you may need more negative camber in the rear.
Sent from my SM-G920V using Tapatalk
lou06483
East Coast,USA
Audi and VW
Respectfully- there's NO camber adjustment on the rear axle.
FWIW--very slight adjustments can be had by moving the sub frame
Evil Minion
Indianapolis
Yep, as has been said, alignment.
On a side note, holy tread cracks!!! :eek: Were you running these below 45°F or something?
Best course of action is to get an alignment while you are having new tires mounted.
ATR
Baltimore
'17 Golf R 6mt
Surprised that no one mentioned tire pressure...
If the inner part of the tread is as low as the outside yet the center shows more tread this points squarely at running the tires with too little pressure. COLD PSI is 39. I typically use 40psi after I drive to the place locally that has free air.
