Hello everyone, im hoping that some of you on here may be able to give me some help with this? Basically, ever since I got my GTD, it has had an intermittent issue when starting from cold, where it will take what I consider to be a longer than normal time to fire, or will stutter before firing up. This usually happens when the car has been stood at work all day. Once started, the car runs fine and if left for a short period of time, will also start fine. There is no power loss or other issues with the car. Oddly though, if the car is stood overnight, it will most often start fine the next morning, It seems to be if the car has been stood for about 10 hours or so that the problem occurs. I have had the car into VW twice for this, and they have all but washed their hands of it , saying that if it doesn't fault when it is with them, they don't admit to a problem. VW first changed the lift pump in the tank, but this did nothing, and they are now not intending to carry out any further work to try and solve this. I have several recordings of the fault (see below), but this doesn't seem to have any sway with VW. I am hoping that from these recordings, someone on here may be able to push me in the right direction please, as I don't think this is normal for a 2 year old car at all!! Battery volts are fine with engine off (approx. 12.6V) and engine on (approx. 14V) and the car appears to crank at a good speed, so I am stuck on this one :/ Any help would be much appreciated with this - please see videos below. Many Thanks,
https://www.youtube.com/playlist?list=PL9Ls7X7QYplLbjDc0tEkaHLYzXuZwSrnC
Apologies for the large number of videos, but it has come to recording the vehicle each time it starts just to try and get enough proof together to try and get VW to actually do something about this!!!
