What does maintenance manual say about front camber?
rexneffect
If it's out of spec - does the VW maintenance manual allow for any adjustments of front camber by other means, as it seems not adjustable from factory.
Thanks!
Sent from my SM-G900V using Tapatalk
GTI Jake
Charlotte, NC
There's no factory front camber adjustment, you'd need camber plates. Or, just buy coilovers or air ride that includes them and kill two birds with one stone
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
or find the damaged suspension part causing camber to be out of spec and replace it.
camber plates are no walk in the park labor wise, tend to require periodic maintenance, and can introduce lots of NVH. Most on the market are purposed to introduce excess negative camber for spirited/competition driving with limited concern for ride quality or nvh.
Sent from my Nexus 6 using Tapatalk
PouncingPanzer1
There is no front camber adjustment with stock suspension components.
The only way you could directly affect the camber or caster with stock setup is by shifting the subframe.
