SmoothCat565
- Massachusetts
- 2017 VW MKVII GTI
Is there a way to fix this stupid problem? It's so annoying.
I have to basically reset my throttle body on a weekly basis to get somewhat normal throttle response, but even after a reset, issue always comes back. To summarize the problem, imagine you try to rev your car in neutral to test it out for responsiveness, but then the rpm's dont even move, so you do it again and then the rpms sort of increase, so you do it a third time and finally the engine responds somewhat normally with a real rev but still kinda trash and not super responsive. I don't know how else to describe. It's like I push the pedal and don't get anything out of it - what??? Only way that's fixed it kind of is to do the throttle body reset where you push down the pedal.
This started happening immediately after I got a trans swap done at the shop because I drove kinda crazy one day and broke 4th gear on the original trans.
Is there a way to systematically determine what the hell this is? Questions like, do I need a new throttle body, do I need to do a throttle body adaption or is that hit or miss and could mess things up worse, do I need to replace something completely different? Is it a sensor?
I really don't want to do this fix through a shop because nobody is gonna believe it and it's sometimes a problem and sometimes it's not type of thing
