The perfect GTD rear diffuser ?
bigtallbloke
Poole, UK
Is anyone aware of a full fill centre piece for the R bumper that would allow a simple downturned exhaust tip?
Something like this from the MK4....
s7wag
Bedfordshire, UK
Milltek Rear Exhaust
AMD Essex completed mine for rear section only - you'll need an exhaust company that can weld the join on the rear. You just need the Milltek rear section. It is modular so you don't have to buy the whole cat-back exhaust. You'll find more pictures and details on this forum.
This is the twin GTI style but you can get the single twin pipe exit too.
Steve
s7wag
Bedfordshire, UK
have you looked at all other Mk7 Golf models to see if any of them have down-turned pipes hidden behind rear valence. My Mk5 GTD had the same too. But Milltek built me the exhaust to match with hidden pipes..I'm sure you'll find a valence
Sootchucker
Cheshire, UK
MK7.5 GTI (2018)
From your friendly dealer:
Part Number Description Qty
Filler Piece LH 5G6807509 1
Filler Piece RH 5G6807510 1
Star Head bolt 5x20 N91090701 6
Speed Nut 5x16 N90959101 6
Blade3562
Earth
None
Just FYI the egolf bumper trim should bolt up. I had a part number, I'm looking again. I'd like to do this on my Golf myself!
paul83
Ireland
Hopefully the new facelift rear diffuser will fit my current mk7 GTD. It's a far nicer finish that the existing one!
Just need part numbers when it's released
St. Olaf
Bumpers cannot be the same as the Estate's is noticeably longer.
Since both hatch and Estate wheelbases are the same, it's the
rear/trunk area what makes the Estate longer.
