A lot of guys seem to like a heavy pedal. I am not one of those guys since my car is a daily and want it as easy as possible for both me and my wife. I know I can’t have everything and a new clutch holding more power will result in a heavier pedal, which is fine to some degree, but looking for the closest to stock as possible. I only plan on going stage 1. Any recommendations are appreciated.
Thanks
Fact:
I single disc clutch will have way more pedal effort with similar holding force compared to a twin disc clutch.
That's the point of a twin disc. All this holding 'power' with ease of use on the pedal. For this model year the Mustang GT's come with twin disc clutches and the 6th gen Corvette Z06 came with them too.
Don't get hung up with "stage" numbers and worrying about a heavy pedal.
If you want an easy to use clutch, look for something with an organic disc, if you want to hold over 400 ft-lbs(APR stage 2 is 404 at the crank which is what all clutches are rated at btw) stay away from any single disc clutch that's not TTRS setup IMO. You're keeping the DMF which will suck ass in performance driving. It'll be quiet, and you'll have to replace it eventually, but you do get less shock going through the transmission if you drive like the dude earlier talking about 6th gear clutch slip.
If you're basically going over 400 ft lbs(basically any stage 2 offering from any software out there) there's no clutch that's going to do the job better than the DKM twin disc. You're getting rid of the DMF, you are using organic discs that are forgiving so you don't have to worry about it being a lightswitch pedal, and the overall effort once broken in is maybe 20% more than stock. As for chatter, you can hear it if the radio is off. The injectors are still louder. You can only hear it at an absolute stand still, with your foot off the clutch pedal.
Everyone else's SMF setup's will chatter like hell and have all the pedal effort in the world because they're only using one disc to do the job instead of two.
TL;DR:
SMF: DKM Twin disc, it's their Stage 3 and good for 660 tq. This is like getting a DSG tune on a DSG car. It makes that much sense.
DMF: OEM TTRS deal. It's still not used on anything warrantied past 400 ft-lbs but the manufacturer rates it higher than what VW is throwing at it.
