10/10/16 - Clubsport Rear Sway Bar and VW 'Driver Gear' Springs
So.. I've actually had these DG springs sitting around for some time, but decided what better time to install lowering springs than right before winter and during a snowstorm haha!
Actually, I wanted to use my buddy's shop for the install rather than do the 2x4" method - more on that later..
Here we are, parts eagerly awaiting their new home. Notice I have already swapped the Superturismos for my winter setup - OEM 18" Durbans that came stock with this 1.8T
I won't belabour the install process here, as there are several DIY examples readily available with a quick search that should answer all your questions.
Driver's front freshly installed.
While I am in no way knocking the 2x4" method in favour of using a hoist I was a little suspect of jacking up on the spring perch, and figured I would do the R&R based on how VW would do it.. Looking back, after it was all said and done I think I would give the 2x4" method a go as removing the axle bolt and associated components proved to be a bit of a PITA in it's own right. But, what's done is done and I honestly don't know which method would be quicker. Obviously if you're doing a spring install in your garage without a hoist, the 2x4" method sounds pretty slick.
Now on to the rears..
Here is the Driver's rear DG spring freshly installed. The rears are a cake walk compared to the fronts.
So pretty. (sorry for the dirt on the rest of the undercarriage, it is our DD after all
Clubsport RSB
I took this opportunity to install an uprated RSB used on the Clubsport GTI. As far as I am aware it is a euro-only piece and as such I had to have it brought in from Germany. It might be spec on some PP GTIs but I have not seen any confirmation on this, as everything I have seen so far shows that the PP rear sway is 3.0mm wall thickness whereas this is 3.6mm.
Here is the stock RSB from the 1.8T (top, dirty), and the CS RSB (Bottom, shiny)
The stock RSB on the 1.8T is a 19mm bar, an I assume the wall thickness is somewhere around 2.5 or 2.6mm.
The uprated CS RSB is technically 21.7mm x 3.6mm wall thickness. This should prove to be a nice, subtle but noticeable OEM+ upgrade suitable for a DD that gets driven spiritedly
Also notice how much 'shorter' the CS RSB is compared to stock - this should definitely prove to tighten things up where it counts, and be a nice compliment to the DG springs.
No muss no fuss, bar bolts straight up - OEM+
Now for some rough FTG measurements
*All FTG measurements were done on level garage floor, car is stock weight, nothing removed or added that should affect the suspension. Brand new Michelin X-ice winter tires in 225/40/18 on 18" x 7.5" OEM Durban wheels. Tire pressure 37psi/corner
** I should also mention that this 1.8T came with OEM 'Sport Suspension' which was an option in Canada, not sure about other regions. From new, this golf already sat lower than the standard 1.8T with regular suspension.
Stock Sport Springs
Front 26 7/8" FTG
Rear 26 3/4" FTG
VW Driver Gear Springs
Front 26 1/8" FTG
Rear 26 0" FTG
Approximate lowering over my Stock Sport Springs right now is .75" front, .75" rear. I will update the DG FTG after the springs have a chance to settle. Compared with my 2016 Golf R with DCC on stock suspension, the golf 1.8T now sits about the same.
I know it's not a DRAMATIC change, especially over the sport springs that came with the car, but for me and my goals with this car they are just about perfect. As I've mentioned before, this is our primary DD which will see all sorts of road conditions, and frankly, lower is not always better when it comes to driving dynamics.
So far I have noticed a subtle but pleasant increase in the firmness of the ride, and much of the body roll has been eliminated. If the 1.8T golf handled like this from factory with these springs and RSB I suspect more people would be inclined to choose this little golf over a GTI.. I'm slowly bridging the gap haha!
