Navi
- BK/NYC/Hamptons
Cylinder 1 Def looks hot. Wonder why
I bet we'll all get our next revisions in a day or 2 once Alex catches up. I'm getting crappy knock on normal driving. Could be ghost knock idk. It's been happening this last week a lot. Taking off from a red light or stop sign its like clockwork.Added enough 100 octane to get to about 95 octane average. Knock is less sustained, but still seeing more of it than i expected.
Threw a fresh set of plugs in it. Had 9200 miles on my last set of IKH24s, and there is some wear showing.
Cyl 1 plug looks hotter than the other 3 (much lighter color), but doesn't show any more knock than the other cylinders.
Hopefully the plugs help clear it up, i'll log it again tomorrow.
Sent from my ONEPLUS 5T using Tapatalk
How do you guys monitor the knocks, with the Cobb gauges or logs? I’ve been checking my logs and have been getting some knocks here and there, don’t know if it’s significant enough for me to worry about but it isn’t as smooth compared to my last revision.
Another question to add on to this is; is it really knock that is being talked about or timing pull to prevent knock?
(Derushi, hope you don’t mind me piggybacking here.)
looks like Alex got back to town this weekend and did a few tunes to knock them out, i have a fresh and almost final iteration sitting in my inbox as of yesterday - putting in that over time! once alex gives me the go ahead that this is the final tune, i will be scheduling a dyno with the local dyno shop (Carolina Dyno here in Wilmington, NC) so i can give him and you all some graphs
I monitor it on the AP gauges. I have boost, knock correction for all 4 cylinders and afr. Logs are good for wot runs so you can see where exactly the problems are but the real time monitoring is really nice.Another question to add on to this is; is it really knock that is being talked about or timing pull to prevent knock?
Great news looks like we're all mostly near the end. I believe my next is my last. The is20 really is a tq monster. A lot of times I need to leave traction on for pulls in 3rd gear or I'm all over the place. My logs are pretty damn clean. Not as good as my 4th revision where every log I took was spotless but he's been pushing it more so that's expected. I believe I've got a semi local shop having a dyno day soon here in Florida so I might finish just in time!
The main concern is knock during WOT pulls. A little correction here and there while driving is normal, and the car is just doing its thing. Like pulling away from a light if you get a little -1, -2 that's nothing to be concerned about. These cars are very quick to pull timing.
Went over log 1 real quick it doesn't look bad at all. Kinda hard to see on my phone but you had very minimal
It is on the higher side, but it's pretty quick and only 1 cylinder. I'll say it took me a few fill ups to totally get rid of the shit gas I had. Even after adding e85. I think these are just really aggressive tunes and certain has its picky with. Yesterday morning going to work I did a random pull and got some knock like you see. In 2 cylinders. Then 5 minutes ago I was out driving and ripping around in 2nd and 3rd and it was perfectly clean.Cylinder 4 really is a grumpy little bitch.
Still on 95 Octane. I might run straight 100 to make sure this knock is completely real.
I realize this isn't terrible, but still more than i'd like to see with the little bump in octane.
https://datazap.me/u/hoon/log-1522102211?log=0&data=4-6-15-16-17-18&zoom=30-123
