My timing belt cover gaskets were leaking so I had them replaced, ever since then I’ve had these DSG issues. But I do all of those driving behaviours lol, like when you’re in a drive thru how do you not coast on the brakes?!
Ok..., perform the in car, reset, by holding down the kick down switch as described in the first two clips, report back. This is weird if it just started all the sudden.
These cars don't have a belt, chain...
Both the upper (plastic cam cover, and/or just the gasket) and lower (stamped steel), were replaced or just the upper? or do you know?
Was the work done at a dealer or indy shop?
Was it flat rate warranty work, or did you pay out of pocket? Assume not warranty, since you have owned it from 7 years... so the chances of a flat rate rush job are less, but not completely gone...
Miles on the car?
Does it happen just in D mode, S mode, does it happen in manual mode 1 to 2, 2 to 3? 3 to 2, 2 to 1? into and out of 1 and 3? or out of 2? Heavy, medium, light throttle all exhibit the same behavior?
Do you have a tune? engine or dsg, or both?
Did the dealer"perform" a "road test" after the work? If the DSG shifting issues, just started all the sudden it would make me wonder.
You do all those "driving behaviors"? Like constantly dragging the brakes in stop and go traffic, the ones (not great for DSGs, in the long run...)? Slipping clutches for long periods of time?
When is the last time you had the DSG serviced?
Have you had the car scanned for codes?
If you perform(ed) the in car reset (in the top two videos) and it gets better, but hasn't gone away completely. I would perform a fluid change and a full adaption reset with a proper scan tool.
If you do all three and nothing changes.....
I would say with what the information given, would indicate, your trans clutches are on their way out, and/or mechatronic valve body is filled with clutch material from possible premature clutch wear from your driving "style". Haven't changed the fluid in 7 years? oof, or taken the time to understand how the trans in your enthusiast model golf? Or it was on its way out, (reply with potato, if you are reading posts in entirety...if you don't, expect my next posts to wish you good luck) and a couple brisk accelerations and or a couple of attempted launches on a cooler trans, from a young(er) dealer tech, who doesn't really know how to enable launch control, contributed to this current state/behavior.
If none of this behavior at all was exhibited before,
this is all just educated speculation, with the information you have presented, thus far...perform the described reset(s) and report back...if the aided problem solving on the forum is overwhelming you, I would reccomend, just taking the car back to the dealer and paying to be troubleshot, and hope they are good, and upstanding enough in their business model to assist. I have found Dealerships(and large auto chain(s) maintenance shops) to be in the 1 out of 3 range, and indy shops(not large chain...) in the 2 out of 3 range, for being mostly helpful/honest.
