Retrofit: Lane Assist MK7 VCDS help
oldsklaudidub
NY
2017 MK7 Golf Sportwagen w/ factory ACC.
Retrofit Lane assist camera (windshield, harness, etc.) Wiring configured into CANBUS module and ACC. Lane assist camera was calibrated.
Running into an error after programing VCDS. Display states Lane Assist Not Available when trying to select/activate function.
Log attached. TYIA.
  • Log-SPTWAG-3VW017AU0HM506795-70720km-43943mi-lane assist .txt
xabhax
15 GTI
Got a code for the steering angle sensor. Gonna have to calibrate that first. Do that then post a scan.
oldsklaudidub
NY
I was able to calibrate the steering angle sensor. New log attached.
  • Log-3VW017AU0HM506795-70930km-44073mi.txt
xabhax
15 GTI
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 70720 km
Date: 2022.07.17
Time: 10:31:28
Supply voltage: Terminal 30: 13.7 V
Terminal 15: On
You ran the two wires from the camera to the radar?
oldsklaudidub
NY
U0235 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 70720 km
Date: 2022.07.17
Time: 10:31:28
Terminal 15: On
That is correct. To pins 5 and 6 on the ACC radar connector.
oldsklaudidub
NY
I think I was able to fix 131671, connector was not seated.
Cleared and rescanned A5:
3 Faults Found, down from 5.
1123699 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 70930 km
Date: 2022.07.23
Time: 13:56:42
Control Module temperature: 76 °C
Outside air temperature: 32.5 °C
Vehicle speed: 0.00 km/h
System run time: 251.9 s
Voltage terminal 15: 13.6 V
mid: 01 AD
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1122664 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 70930 km
Date: 2022.07.23
Time: 13:56:43
System run time: 252.5 s
mid: 01 F0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1122597 - Local Data Bus
U1169 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 5
Mileage: 70930 km
Date: 2022.07.23
Time: 13:56:42
System run time: 251.7 s
mid: 01 43
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
xabhax
15 GTI
Camera is working, just coding is left. I'm gonna try and find a break down of the coding instructions.
xabhax
15 GTI
On page 233 of the xagico pdf are coding instructions
Xagico PDF
xabhax
15 GTI
You should be able to just download it from that link.
xabhax
15 GTI
I tried its too big. Pm me your email I can send that way
xabhax
15 GTI
Or just Google xagico pdf. It's posted all over the place
oldsklaudidub
NY
I was able to download. Went through the steps. I am still coming up with a few codes. Instrument clusters stats "Lane assist not available"
Log:
  • Log-3VW017AU0HM506795-71135km-44201mi.txt
