The bulbs lit up and worked fine for a few minutes. Then the error codes popped up. Next I ordered the wiring harness to eliminate the error codes and installed. Got the error codes again. Went back to factory set up and returning everything I bought.
Will look for better bulbs and try again.
Bulbs I bought were the H11.
https://www.amazon.ca/gp/aw/d/B01ET262MO/ref=yo_ii_img?ie=UTF8&psc=1
Those are the lights I bought.
Any help is appreciated!
Looking at the link from where you bought those bulbs I notice the following:
They do not specify an operating voltage.
They are LED bulbs.
From my understanding you cannot just put an LED bulb into the fog light fittings as the LED's require some sort of ballast/driver. I replaced my OEM fogs with a halogen bulb (basically the same as the OEM) but with a whiter colour. I specifically avoided replacing with LED or xenon bulbs for this reason, I was looking for a cheap and quick alternative.
If you want to put LED bulbs in I suggest you find a thread where someone offers guidance/advice on this matter.
Other than what I've just said I don't know what the error would be caused by, but I suspect it may be as mentioned.
Good luck with resolving it!
