isotonic_uk
- United Kingdom
Hi All
Was wondering if anyone can clarify an issue I have seen on my MK7 Golf. I think I may contributed to the problem as well.
Yesterday before I left for work I was in the car park talking for about 20 minutes with work friend, during this time the car was on and stationary, after I left about 30 minutes on the motorway I received a error about my oil temp was too high, the car I believe went into limp mode (not sure as there was a lot of traffic so was going about 30 anyway), I saw the oil temp needle right at the maximum temp which is 130c.
I pulled to the hard shoulder and waiting for 5 minutes before starting up again and then carryed on, throughout the remainder of the journey I was playing russian roulette with the temperature as it was rising and going down, I heard from a friend a long time ago that actually putting the heater on high and opening the windows should help, i tried this and it did keep the temperature controlled.
Went to work this morning and all seemed to be ok. The oil hasn't risen to that high level. Before I left I did check the coolant level and thought it was a bit lower than what I have seen it previously but I believe still under acceptable levels. I have also in the last 2 weeks had the oil warning light appear to say its due but just haven't had the chance to book it in yet.
See image to show coolant level: https://img42.com/ipbLL
So did leaving my engine idle stationary for 20 minutes contribute to the temperature going so high?
Appreciate any advice on this.
Thanks
Thanks
