Ok, first off this thread is amazing! Thank you to everyone for the input. I ordered all of the parts (that friction disk is a pain to find right now) and plan on installing here in a few weekends. But there are a few outstanding questions and concerns I have after reading all 24 glorious pages here.
1) Torque specs on tty bolts and other "critical" bolts (ie pressure plate, hubflange, etc...)
- Are they the same as the mk6 as called out in this post? (
http://www.golfmk6.com/forums/showthread.php?t=73022)
2) Transmission fluid.
- Sounds like a little may leak when removing/installing. Should I drain first and then refill with the drained fluid after? (Slightly less weight in transmission removal and I'm not risking the actual liquid gold (sorry velveta) that is this g o52 527 a2 fluid leaking onto the ground). If I leave the fluid in in how much can I expect to leak?
3) PP and VAQ.
-Any special tricks or tips for the install when dealing with the diff?
4) Downpipe time? Other upgrade time?
- Seeing as how it needs to be removed I am debating whether or not I should spend the money I saved on the install by treating the ol' girl to a nice Neuspeed dp. Could go either way, just hoping for a nudge based on difficulty in getting the stock out as I plan on getting one eventually anyway. Anything else that may be good to do now that I am doing all of this work?
5) Clutch alignment tool.
- Do I really need the T10097 vw centering tool or will the sachs tool work? I can't find a T10097 for under 40 bucks not on backorder and not sure if I should wait or choke on what little pride I have left and just have another 40 dollar one use tool sitting in my garage.
Thanks in advance and sorry if I have asked anything here that had already been mentioned in the tome that is this thread
