Ezekiel81923
- Royersford, PA
- 2019 Volkswagen GTI
I've seen threads relating to this before but I haven't gotten a definitive answer. I've also searched other forums and have not been able to replicate what they are saying.
I find hill hold annoying, and I'm not here to discuss the merits of it or why VW programmed it into our cars, I just don't want it. I know in OBDEleven under Brakes 03, in adaptations, you can change "hill-start assistant" between late, normal, and early. I changed it to early and tested it out and I'm fairly convinced it made no difference. There is still a hold for at least a second even on slight hills.
I've read of a setting "right under that" (I don't see it) where you can adjust the threshold at which hill hold engages. From the sounds of it, stock setting is a 3% slope and changing it to, say, 10% would greatly reduce the number of times it intervenes. For me anyway.
But I can't find anywhere in OBDEleven where I can adjust that. Does anyone know if it exists, or what that adaptation is actually called?
MK7.5 GTI. OBDEleven NextGen Pro
