Looked at my one log from track and did see a big dip in rail pressure for about a second and went back up. Afr went about .5 leaner during that time but wasn't too horrible and not sure where to look at injector info. This issue hasn't showed in 3rd or 4th gear only logs. I'm about E35-E40 now so might need to drop it back down to E30.
It wouldn't really show up during logging because the pump uses the fuel to cool itself. If the tank is running low/high ethanol content so it is running hard, it can overheat and fail to provide full pressure when running WOT for ~11-12 seconds.
Back down E content 10%, leave tank above 1/3rd.
No need to look at injectors as the AFR and fuel pressure will tell the same tale.
