Salami
- North Carolina
- MK7.5R
So my being an impatient dumbass did I installed a few mods over the period of two weeks. Now I got a noticeable vibration and I'm not sure what is causing it.
2019 Golf R DSG. Downpipe went in first. Then used BFI engine and transmission mounts a week later. 6 days later stage 2 ECU and TCU tunes.
I noticed it first driving after I flashed the ECU and TCU tunes. I am wondering if I messed up the sequence of torquing the fasteners down on the BFI engine and transmission mounts or if something isn't aligned correctly.
Got a vibration that occurs between 1800-2200 rpm but RPM depends on gear. Under light acceleration (20% or less throttle) if I lift off throttle just after an upshift as the car decelerates there is a noticeable vibration. If I lightly tap the throttle while vibrating it will stop.
