steveaustin
- OR
If your'e using OBDeleven, this seems to be a common problem. Oftentimes before I set out to make adaptation changes I will change diagnostic service modes on the main screen of the module I want to perform the changes to. Go to Change Service --> select VW Diagnostic Service Mode. Then go to Adaptation or Long Coding to make your changes. This seems to eliminate a lot of the "function not available" errors I would get. Not all, but many.
Great, thanks for the tip. Do you recommend changing all the items to unblocked in this area? I see different people posting things to say change all or only change a few. Would unblocking all cause any harm?
