supesgolfr
- The Net
that's the weird thing. Why does this happen to some people and not others? Why does Dimmwert AB 28 127 work for JBale, and not Audiamant?
Don't know you you could not install them properly when all wires are color coded. Pin 4 is green pin 5 is grey I believe, your brake and running will flip flop depending on what pin your in.Does anyone have pictures or install video with AM harness? I can't seem to get em to work and would like to verify that I have the wires in the right connector slots.
Sent from my F8131 using Tapatalk
The instructions didn't say what connectors the wires go in so that threw me off. I did see this picture as well and was using as the basis for the wiring but again, didn't get the connector info in the picture. Appreciate the clarification.Don't know you you could not install them properly when all wires are color coded. Pin 4 is green pin 5 is grey I believe, your brake and running will flip flop depending on what pin your in.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Hey the long wire with module goes to the inside light, the shorter one goes to the outside light. As for the wires, mine wer red and green and you just connect red to red and green to green, my wires had ferrules already on one side so I could join themThe instructions didn't say what connectors the wires go in so that threw me off. I did see this picture as well and was using as the basis for the wiring but again, didn't get the connector info in the picture. Appreciate the clarification.
I may just contact AM and see what they say!that's the weird thing. Why does this happen to some people and not others? Why does Dimmwert AB 28 127 work for JBale, and not Audiamant?
Sent from my GT-I9300 using Tapatalk
But they do work, just not when I turn on ignition. I'll have a look after work todaydisconnect the interiors!! test if the dynamics work
you'll get a light fault in instruments,when I reconnect it disappears
use google translate sorry
But anyway, I don't mind whatever coz I set my tails to "on" with DRLs (suggested by Raf), which is better than Scandinavian tweak where license plate lights are also on.
I'll send u a vcds backup if u want. Marcel coded mine and they work flawlessly.So finally got the wires hooked up but ran into some coding issue. Worked with Marcel for roughly 3 hours this morning and still no resolve. I'm sending him the OEM coding and hopefully we can get this addressed quickly, hopefully before Saturday cause Cars and Coffee.
I will gladly take you up on your offer. Much appreciated.I'll send u a vcds backup if u want. Marcel coded mine and they work flawlessly.
Nope I overwrite my oem with AM. When you do vcds backup it doesn't call it 1,2, etc in the folder it just writes over past file. I can get you the code tomorrow.Did you create a backup of your values before you applied AMs code values? I'm using obdeleven as well and I sent Marcel the backup so he can try to figure out why the codes weren't working.
