Hi prior to m ownership, my vehicle was retrofitted with Mk7 R Bi-xenon/LED head lights and mk7 rear tail lights. I'm assuming It previously had 7.5 standard DRL halogens, because it has the adapter conversion loom to make the headlights work. The headlights work fine aside from the irritating 'vehicle lighting error' on start up. I don't think i have the AFS function or adaptive headlights, or relevant modules installed, they're not coming under Installed, section on main vcds page,
I have vcds hex net / usb,, but a complete novice. The scan of the central elecs module indicates incorrect coding of light module, see scan below, Is it because its not a medium or high BCM ? i need someone to please walk me through coding adaptation process if it's possible to code or adapt out the error code.
Thanks in advance
Friday,12,May,2023,18:49:52:06045
VCDS Version: Release 23.3.1 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 5Q0-937-08X-V2.clb
Control Module Part Number: 5Q0 937 084 DB HW: 5Q0 937 084 CE
Component and/or Version: BCM MQBAB M H38 0273
Software Coding: 7A99CB2A08A90900003000302C4880C00FC2404060030000300010000000
Work Shop Code: WSC 19460 666 12345
ASAM Dataset: EV_BCMMQB 019001 (VW37)
ROD: EV_BCMBOSCH_019.rod
VCID: 7BA89AE1A36419025A9-802E
Fault Codes have been Erased
1 Fault Found:
526615 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert->Keine Anzeige]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.0 V
Outside temperature: 14.0 °C
Thanks in advance
www.Ross-Tech.com
1 Fault Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
