Luvs2speed
- US
I had a really good deal available to me on a full set of brakes off an MK4 R32 but after alot of research I cannot confirm if they will bolt up. I know ECS sells the MK5 kit with carries and those do fit. It also seems that we share the same carrier spacing as the MK6. I cannot figure out if the MK4 is the same.
I would be getting MK4 R32 capliers, carriers, SS lines, rear rubber brake hoses, and hardware all stock. The front rotors are 334x32mm and the rear rotors are 256x22mm.
Here is a link to the ECS kit and it appears to use stock MK5 carriers.
https://www.ecstuning.com/b-assembled-by-ecs-parts/front-big-brake-kit-ecs-slotted-rotors-345x30/011149ecs01-03kt/
Any help is greatly appreaciated.
