i want to make my vehicle road compliant, previous owner had a decat and mostly straight piped through,
I’m wanting to reinstall a sports cat but want to be sure of the original location of the OEM standard CAT ?
How many CAT’s do these cars have ? It’s the 1.5 TSI DACA engine.
I’m unsure whether there was another CAT after the turbo downpipe GPF and flexi joint ?
I’ve tried Googling and not many pics come up of the OEM setup. Can someone confirm the 2nd pic attached below is the original OEM setup ? and am I right in assuming the CAT is the bulky horizontal piece situated after the downpipe flex joint and mounting bracket ? because this is defo missing on mine.
In the 2nd pic attached of my vehicle you can see that during my ownership I have had a small straight Power flow resonator installed, to quieten the drone and excessive noise. The original larger silencer would have been located slightly further back. Looking at 2nd pic, is there sufficient space to weld a cat back in between front red mounting bracket and the 2nd metal round joint bracket ? Is it an issue if the centre resonator is situated only a short distance from the CAT ?
pic 1 is Google pic of supposed OEM setup and
pic 2 is current setup on mine.
