Happy wife, happy life...
So true!
Those who have had both PSS and PS4S: Do the PS4S run as wide as the PSS? Planning out my summer fitment and guessing I’ll need the fender screw mod if I go 245/35/19 on 19x8.5, et47, lowered on MSSKits Street with stock camber.
I have 245/35/19 on 19x8.5, et45, but not lowered. So, the 2mm and lowering somewhat compensate? Yes, the screw definitely had to come out; you should just assume you must remove it. There's some minor potential for worse rubbing problems, but I suspect not (just a guess)...
Tirerack carries only one width.
Forgot to ask: got any pics of your 245/35/19 PS4S on 19x8.5 et45? Especially want to see how flush that is with the fender. Thanks!
Here you go...
Can't wait to get the summers back on (and do the APR Stage 1)!
Wonder how the PS4S compares to the Conti ExtremeContact Sport. The Conti probably gives away some performance but its cheaper and has a higher treadwear #. In the real world...?
Functional vents on the hood?
My recent experience with Conti motorcycle tires leads me to think that the company has really stepped up their game in the last two years. Michelin has set the bar high with the PS4S but my sense is that Conti has really stepped up with the ExtremeContact Sport. The glowing reviews on Tire Rack make no mention of noise and some of the drivers had racked up 15-20K miles. They also mention that the wear rate was impressive.Based on prior experience with Continental performance/summer tires, the Conti tires will have excellent grip, but after about 7000 miles, they'll be so noisy that you'd rather gnaw your own leg off than drive more than 50 miles at a time. The Michelin tires won't. Then again, it has been some time since I've had a set of Continentals on my car, so maybe they've stepped their game up in that respect.
I hesitate to say yes on vent functionality. The last time I answered yes to this question led to a grilling that lasted for a week or more. My evidence is a longer warm-up time to normal operating temperature.
But to (hopefully) provide an acceptable answer, the vents have trays that carry away the water, but also provide plenty of air flow between the environment and the engine bay.
Frankly, I’m less concerned with functionality, more on aesthetics: I love the look over the stock hood. Losing 22 pounds is a minor plus, as well. At $2000, not sure it’s a great value. I like having a racier look that’s also quite stock-like...
