Just want to let you know that there's a toolbox for the Discover Media as well: mib-std2-pq-zr-toolbox on github.com
This toolbox is designed to give you deeper access to the filesystem, modify system skins and sounds, remove some of the system restrictions (for example CID-Lock for navigation SD cards), access and change part of the coding and adaptations of 5F unit, enable FTP access to filesystem, and more.
Installation
Toolbox installation
CID-LOCK removal
Fixing error 1556
FAQ
Will it work on my unit?
If you have VW Discover Media, MIB2 made by Technisat/Preh - yes.
Press and hold MENU button for 3 seconds, select update, and check software train. If it ends with "T" - you have Technisat/Preh unit. If it ends with "D" - you have Delphi unit.
Does it work on Delphi units?
No.
Does it work on Composition Media?
Technically yes, but not with the simple SD card installation method. You would have to open the unit, dump eMMC content, modify it, upload it back to the unit.
Does it work on Discover Pro?
No.
Does it work on MIB1?
No.
Why I should replace the /cpu folder
Software 1xx and 2xx is using GEM (green engineering menu) version 3.4 and 3.5 which will not work with the toolbox right away.
You need to use a different installer to additionally replace GEM with newer one.
How to enable developer mode with OBDeleven?
Connect with module
Select diagnostic session:
Go to
Select channel:
Change value to:
Reboot the unit.
How to enable developer mode with VCDS?
Connect with module
Select
Enter code:
Go to
Select channel:
Change value to:
Reboot the unit.
How to reboot the unit?
Press and hold volume control knob for 10 seconds.
Installation
- Make sure that you have supported unit in your car.
- Make sure that you have enabled developer mode with OBDeleven, VCDS, or other diagnostic tool.
- Check what software you are running.
- Prepare empty, FAT32 formatted SD card. The bigger the better, but 1GB will work.
- Download latest release from here.
- Extract the release to the SD card.
- ONLY if you are running software 1xx or 2xx: replace the
/cpu
folder in the root of SD card with the one from/toolbox/gem
. Check FAQ to know why. - Go to your car, turn the ignition or engine on, remove SD cards from the unit in the glovebox, insert SD card with the toolbox into the slot 1.
- Press and hold
MENU
button for 3 seconds to enter Service Mode. - Press
Software update/versions
,Update
,SD card
,MIBStd2_Online_Approval (V432-1)
,Start
,Next
. - Wait. Main unit will reboot 2 times before it will show you list of updated modules.
- Press back arrow in top-right corner. Main unit will reboot for the third time.
- Press and hold MENU button for 10 seconds to enter Testmode menue, select
Green Engineering Menu
,mib2std_toolbox
. - Have fun!
CID-LOCK removal
Fixing error 1556
FAQ
No.
No.
No.
Connect with module
5F
development mode
Go to
Adaptation
Select channel:
Developer mode
Change value to:
activated
and save.Reboot the unit.
Connect with module
5F
Select
Security Access
Enter code:
S12345
Go to
Adaptation
Select channel:
Developer mode
Change value to:
activated
