bobloblawGTI
- DC
- 19 GTI SE 6MT
Looks like your previous E0220D firmware was modified to enable some features.Hello. I have just upgraded my firmware from MST2_EU_VW_E0220D to MST2_EU_VW_P0231D_MU633 as per the advice in this forum. All worked OK but now when I plug my phone in it says 'app connect - you can activate this function by means of an activation code. Please contact your dealer'. Also all the phone features have disappeared. Is there any way I can get this feature back without paying VW??
thanks for the reply, so it seems to be empty within supported codes?@Ogdonald , you should be fine with this firmware.
http://mib-helper.com/?train=MHI2_ER_VWG13_P4512#details ER region is Europe and Rest of the World. Question is if you have the right FEC/SWaP code for EU maps. Check in hidden menu which codes are installed.
These are what I gotMHI2 are often empty in supported section. Please check installed.
Thanks again, i've got as far as step 3 however i only see ProductionYou have RoW code: http://mib-helper.com/fec-decoder/?fec=093d0008
You need EU code: http://mib-helper.com/fec-decoder/?fec=09300008
Follow this:
1. Update to MHI2_ER_VWG13_K4525
2. Download M.I.B.-More Incredible Bash (from github) and patches (from mib.mibsolution.one)
3. Install M.I.B. in your unit (use quality SD card)
4. Use M.I.B. to patch your system. It will automatically add EU code if I recall
5. Before installing EU maps you will most likely need to remove old RoW maps first. There should be an option in M.I.B. for it as well (format Nav partition or something like that)
6. Update with EU maps.
Does this mean I've done something wrong?You have RoW code: http://mib-helper.com/fec-decoder/?fec=093d0008
Follow this:
i didnt remove the SDcard but i didnt install the patchesafter installation don't remove SD card.
