Lighting Fault
Dagobah
Nottingham
Since owning my car I have had two bulbs fail on me (well, one blown headlight bulb and a brake light bulb that had only fell out of its socket) and each time the Vehicle Status has highlighted exactly which bulb was at fault.
The problem I have at the moment is a "Vehicle Lighting Fault" that does not state which bulb. I have checked every bulb inside and out and they are all OK. The warning chimes up as soon as the ignition is turned on.
Any thoughts before I call my VW Dealer?
element515
United States
That's strange. I had a turn signal glitch out once and it told me it was the turn signal on the driver's side. I'd just take it in to the dealer and see what's wrong.
Dagobah
Nottingham
Booked in at Dealer 3rd July.
Sent from my iPod touch using Tapatalk
Geomets
South-Eastern Europe
Golf mk7 GTI
I know this sounds wierd, but did you check your battery? I had two French cars in the past, and blowing bulbs and random electric glitches occurred when their batteries were at their last. Go to a garage and check the health of the battery, I'm quite sure it's the root of the problem.
Dagobah
Nottingham
Could be right about the battery Geomets, possibly not supplying enough wattage to the lighting circuit which is on all the time due to DRL's.
rygreen93
Please can someone comment and let us know if this has been fixed. I'm having this issue now. Have checked every single bulb
Sent from my CPH1607 using Tapatalk
ManInTheClouds
OK
Check your car battery, and also get OBD11 so you can read the specific code.
It's a $50 powerful scan tool, idk why not every MK7 owner has one.
Bäsemödel
Lancaster PA
Have you done any mods to lighting? I have done several inclideing euro switch w/piggyback auto sensor, as well as front and rear fogs. Sometimes, when I turn the fogs off I get this message.
avenali312
Mableton, GA
2015 GTI
I had this error on my car. Bought it used and didn't realize the previous owner installed a light switch with the Auto setting, which my car doesn't support. Any time I turned the switch past the Auto setting, it would throw the exact same code.
isotonic_uk
United Kingdom
Hi All
I am now getting this on my car, checked all internal and external lights and all seems to be fine, the only light that isnt working is the rear left fog light, but I have read elsewhere that EU cars only have the one rear fog light coming on?
Can anyone confirm if this is the case? When I look closely at the bulb assembly it seems there is a bulb there but for some reason when I took off the rear cover I couldnt seem to access it.
Any advice on this would be most appreciated
https://www.google.com/url?sa=i&sou...aw3TETItg5i24P4JNxmj6Ieo&ust=1549357759511203
Thanks
IWMTom
Hi All
Thanks
Yes, there's only one fog as per the MOT.
isotonic_uk
United Kingdom
Just to add to this, I have just found out that i have a leak in my boot and water has collected in my spare wheel well. Could this have affected the lighting system and that is why I am getting the fault -vehicle lighting error now?
I did purchase an OBD2 device and tried to use one of many apps on Google play store but was unable to clear. If anyone has any ideas how I could do this it would be appreciated.
Thanks
