JB1 vs JB4 Dyno Data
lamb110
Elburn, IL
Here are the settings on Map6:
Funny thing is it looks the same as the settings on Map 2:
Mydixadryl
Texas
The settings on the left are for Map6 only and ignored in Map1/2.
lamb110
Elburn, IL
ahh makes sense. Well you guys made me feel better, I was thinking there was something wrong because I was looking at the Ign1 was pulling timing, not that it was adding it. Time to turn things up... I'll be putting on a CTS Throttle body pipe, CTS Turbo Outlet Pipe, and the CTS Turbo Inlet pipe. After that they'res nothing left to do other than an IS38.
Venumous
NE
Seems a bit aggressive up top but makes great power. You're at around 320whp on a DynoJet and peak power on most graphs I've seen is at 5500rpm anyway. I'd be pretty happy with that number.
0bLiViOuS
Orange County
Ya your numbers looks great and the torque is nice and flat. You could definitely add some low if you wanted, but I love how flat that thing is. Like others said, add about 10% to the numbers for a typical DynoJet comparison.
illsaveyou
Greenville, sc
Just copied your map 6 and tested it out a bit, let me say i almost pooped my pants when i felt the difference from what i had and all i have is a Forge carbon fiber intake. Good Stuff
themyst
NYC
the delta is +2 whp JB1 to JB4 on different days. with no baselines. hard to quantify what measurable differences there are.
Fillzplace
Vancouver
Reviving an old thread which still has some excellent information in it.
Just looking at these settings after installing my JB4, and a couple of questions;
What octane were you running with Map 6?
Do you think that running this Map 6 without the downpipe (on a stock GTI Autobahn) would have any negative effects (other than some reduced HP from not having the downpipe)?
Oldschoolmk7
Yonder
Interesting. A jb1 bolt on guy a while back hit 303/367 on pump. 5.5 pounds over pretty strong. Forget his handle.
Litokushmk7.5
Califonia
Mk7.5 golf gti
what do u guys think this is map2 with 034 carbon fiber intake and turbo smart blow off valve doing a cts turbo 3.5” downpipe this weekend and going to do a e30 mix and run some logs to set up a map 6 tune what ya guys think i need input im a newby
