dre1615
- Vernon Hills, IL
So the IS38 bug got me a little sooner than I originally planned. I picked up a local second hand IS38 this weekend and it’s over at G-Pop Shop getting balanced and ceramic coated. I’m currently sitting at Unitronic Stage 2 with Uni IC, AWE DP, Autotech Intake, and RSE10’s/VWR springs. So the bases are more or less covered as it relates to bolt-ons. I have a BMS turbo inlet on the way, as well as RS7 plugs and the hardware install kit.
The thing I am having the most trouble with is the tune. I originally went Unitronic for all the same reasons we see here every day. More conservative tune/boost profile, daily driver friendly, at home tuning via Uniconnect, reliable etc. Reliability is still a priority, but the Uni IS-38 tune looks to be a little too underwhelming for me, relative to what some Stage 2 tunes are putting out.
-I can upgrade to the Unitronic Stage 2+ for $800. I’ve seen 352whp/344wtq from Modded Euros but no other dynos or real world experience on this tune. Uni advertises 381/377 at the crank.
-Eurodyne appears to be $700 for tune with OBD reflash tool. Based on what I have read I would have access to all the files at that price (stage 1, 2, IS38, etc.). Someone correct me if I am wrong here. Numbers for this tune appear to be on the higher end, 360ish whp/360-380wtq. Only thing that scares me is the complete lack of customer service.
-JB4 is $429 plus cost for the wireless kit. I have seen a ton of people using JB4 to stack with WMI, but not much info on guys just using JB4 as the standalone tune. Have not been able to find numbers either. I'm not interested at the moment in getting into meth, so I'm not sure if this is a good fit for me.
-APR – Forums have scared me away from APR. Heard their IS38 file is solid, just hard to tell with so much bad publicity on here.
-GIAC – Have seen a bunch of good things from VAG-TECH about GIAC. Have not seen anyone else using it to comment on reliability, performance, etc. Their tune is closer to $1k I believe.
-UM – No local support, not an option.
Wanted to see if the IS38 guys could chime in and let me know what your experiences have been with your tunes, pros/cons, etc. I do understand that it is not just about peak numbers. Most of the dyno plots are very similar in power/torque delivery, just want to make sure I’m getting a good value given the price.
Thanks in advance.
Thanks in advance.
