avenali312
- Mableton, GA
- 2015 GTI
Truly just because APR told me to for stage 2 along with my local mechanic. On top of that, seeing so many aftermarket intakes manufacturerers boasting 10+ hp gains if tuned. If it's not necessary, I'm more than happy to stick with the stock intake and not spend $! It isn't that I'm adamant, more that I thought it was a necessity. Jovian, what would you do? I always appreciate others' opinions. Aside from drop in filter and snowboard removal, would you still install new inlet tube and turbo muff delete?
My issue with the stock intake was clearance of the turbo discharge pipe. When I installed the neuseped discharge pipe the box would hit the pipe/hose. I went with the enclosed injen and absolutely love it. But dyno seems faster but I have no equal playing field. Other mods were installed at the same time. From my understanding replacing the turbo inlet 90 and the flex hose will provide better results than an intake.
When doing an air intake mod, do you have to reprogram the computer to adjust for the increased airflow?
That "snow guard" looks really restrictive.
Sure looks like from this video that it also draws in air from the engine compartment.
Nope. the stock ECU adjusts nicely to the change.
Unless you are throwing a turbo on bigger than the IS38 than the stock air box is totally fine.
I have a K&N filter(any high performance filter will be good) and the snow guard removed. Here is the info: https://www.carworklog.com/2017/01/06/guide-mk7-gti-ea888-gen3-intake-snow-guard-removal/
The turbo inlet pipe I think it more likely to help than an intake. The muffler delete is more just for sound, not much performance.
I don't have any of them done currently but am considering the inlet pipe.
Good stuff. I'll do the same. CTS inlet tube and K&N filter sound like a good upgrade pair for intake.
