Looking online... I see pricing anywhere from $930 to $1090 for the full system. I can't tell if any of them are available though. It pays to look and feel good i guess! IMO this is the best looking intake that I have seen. A little rich for my blood.
I can never understand why someone does anything to the intake on less than a stage 3 car. Oh, I forgot, because racecar, LOL.
For those that have done the dremel mod, how much rain have you driven through since? Have you ever seen water in your airbox? If yes, how much? I would be interested if I could create a neat little duct that I could open and close whenever I wanted. Just not yet sure how I would go about doing this and not have it end up being a hack job. It would have to be strong enough so the cover would seal nicely and wouldn't leak or blow off.
Why would opening the driver's side make any difference for water getting in? All air and water still has to enter from the slits on the passenger side.I've had the driver's side of the air channel Dremeled out for probably about 2 months now and April was crazy with the rain to the point where some of the streets flood around here (New Hampshire) and I've never had any problem with rain in the stock intake box. The only thing I'm doing is checking periodically to make sure that drain at the bottom of the airbox is clear of debris but I honestly haven't seen anything in there yet.
No, air doesn't come in from the driver's side of the grill. It ONLY enters from the passenger side through the slits.It doesn't make a difference... if you looked at my comment I quoted toledospeed and was assuring him that I haven't seen a problem with Dremeling out the driver's side on my ride. Air still does come in on the driver's side under the edge hood though its not all from the passenger's side after the mod. You can hear it just by listening to that side of the grill once its open, especially after a cold start while the SAI kicks in.
I understand that opening up the driver's side allows air to enter the intake there and that it reduces restriction but the only air feeding that location comes from the passenger side of the grill.
No offense, but I'd love to see how you explain how the APR cold air intake works then since it removes the air channel entirely and bolts directly to the top of the grill on the side without the slits, miraculously it still gets air... weird. The hood does not seal air tight to the top of the grill so the intakes that remove the channel still pull air over the top of the grill in the gap between the grill and the hood. I understand it's not a huge gap but it's enough to pull air into. Likewise Dremeling out the air channel has the same effect. Let's just agree to disagree on this one.
Sent from my ZTE A2017U using Tapatalk
