Great thread Dave, thanks so much.
I just split open my second half-tray. damn autocross cones. Really hoping to replace with something more durable (besides replacing the driver
So from what I recall breezing through the thread, 3Q0 825 236 C has a vent and 2Q0 825 236 Q does as well.
Does Q accommodate the brackets?
From breezing through the thread...
here you go:-
thin plastic "Aero" tray NOT the Skid tray:-
There are several types depending on the number of NACA ducts you want...
5Q0 825 236Q gives you two ducts/vents near the front
3Q0 825 236 give you an additional baffle grill at the rear ....(used on GTE)
5Q0 825 236M gives you NO vents so do not get!!
Item 10, WHT 000 729 A, hexagon socket head bolt, self-locking,(M8x20mm), (x3) shorter than the skid tray rear bolts as the "Aero" tray is thinner plastic
All are full size trays & require the rear three bolts, but do NOT require the brackets or front bolts due to the light weight, they also use the existing small black screws...
SKID TRAY VW parts list & approx costs in UK £
Item No. 23:-
5Q0 825 902C, Underrun bar with one duct (Skid tray), £195.73***
Item No. 23:- 5Q0 825 902B, Underrun bar with NO ducts (Skid tray), DO NOT GET as NO air ducts
Item No. 24:- 909 747 01, Black wide head T-star screw A04B, £0.16 (x7)
Item No. 25:- 019 530 7, Flange hex head bolt (M8x25mm), £0.93 (x7)
Item No. 26:- 5Q0 825 921, Retaining bracket, £6.98***
Item No. 26:- 5Q0 825 922, Retaining bracket, £6.98***
Item No. 27:- 907 559 02, Spline head bolt with washer, £1.14 (x2)***
***=Only these items required from the dealers in my project!***
For NAR (USA, Canada, Mexico, etc) Forum member "ADVNTURR" has found that the following parts are easier to order in NAR & do fit as he posts in this thread here:-Click here
Item No. 23:-
3Q0 825 902, Underrun bar (Skid tray), $282.48***
Item No. 27:- N 0195 307, Hex head bolt , $ (x2)***(easier to fit this bolt in tight space but the one above is the correct VW one)
I have confirmed with the VW ETKA & these parts are correct for NAR MK7 Golf, & the tray is from a new Passat hence the "3Q0" start to the part number. The Passat is also an MQB platform car so will share many parts & dimensions.
Highlighted are the full aero tray with ducts & the skid tray with ducts
skid trays require front brackets & more bolts...full aero trays actually called "noise insulation" DO NOT require front brackets...
