notlucaspearson
Afternoon all, I decided it was time I stopped lurking here for help and made an account to ask for help of my own.
I own a 2011 GTI with 130K miles. For the past year or so, I've been getting increasingly more and more weird gremlins and issues with the electrics.
Last year in October, after taking it to be serviced at a local shop, the trunk latch would no longer open when the car was unlocked and it was pulled. It would have to be released through the keyfob. It worked when the car was running however.
I didn't think much of it, and just used the keyfob for a year. Now, in the past month, as I've been trying to fix it, I've had more and more issues.
As of today, the list of issues is as follow:
Right Turn Mirror Indicator No Longer Working (This started happening last week)
Intermittent Extended Crank and Car will often dip in RPMs when idling, almost sounding like it's about to stall. (I believe this to be a LPFP/R going bad, I looked into it a bit)
> Relating to this, car will often start, then proceed to stall if I don't give it some throttle, illuminating the battery MIL in the dash when it does stall.
Inoperative Trunk Latch as said
Right Window will no longer go down on it's own. You have to hold the window down button. (Drivers Side Auto Down still works, as well as indicator)
Yesterday, the car battery was completely dead. I did not leave any lights on. The OBD11 was unplugged.
Engine Bay Fuses
Fuse 23 has blown multiple times, and today I checked and it seems Fuse 22 has blown as well. Fuse 16 was melted, so I replaced that and haven't had any issues.
I have an OBD11 and the codes I'm getting aren't getting me anywhere. I will attach two logs below, each taken on 9/1 and 9/7.
Below is the 9/1 scan:
And below is the 9/7 scan:
I haven't had the time to snoop the wires to look for shorts, since I'm still a student. Any help would be appreciated.
Engine Bay Fuses
Code:
OBDeleven vehicle history log
Date: 2023-09-07 17:25:31 (date exported)
VIN: WVWFV7AJ1BW076967
Car:
Year: 2011
Body type: D5 Hatchback
Engine: CCTA kW ( hp) l
Mileage: 209280 km
Full scan
Control Units: 15
Fault count: 1
Control Units:
01 Engine
System description: 2.0l R4/4V TFSI
Software number: 1K0907115AP
Software version: 0020
Hardware number: 1K0907115AA
Faults:
No trouble codes found
02 Transmission
System description: GSG DSG AG6 511
Software number: 02E300053N
Software version: 2235
Hardware number: 02E927770AL
Hardware version: F11
Faults:
15 Airbag
System description: AirbagVW10G
Software number: 5K0959655B
Software version: 0706
Hardware number: 5K0959655B
Hardware version: 021
Faults:
17 Dashboard
System description: KOMBI
Software number: 5K6920971C
Software version: 0406
Hardware number: 5K6920971C
Hardware version: H04
Faults:
16 Steering Column
System description: Lenks.Modul
Software number: 5K0953507AH
Software version: 0080
Hardware number: 5K0953549B
Hardware version: 007
Faults:
09 Central Electrics
System description: BCM PQ35 M
Software number: 1K0937086L
Software version: 0615
Hardware number: 1K0937086L
Hardware version: 104
Faults:
08 Air Conditioning
System description: Climatic
Software number: 3C8907336AJ
Software version: 0305
Hardware number: 3C8907336AJ
Hardware version: H14
Faults:
03 Brakes
System description: ESP MK60EC1
Software number: 1K0907379BC
Software version: 0106
Hardware number: 1K0907379BC
Hardware version: H30
Faults:
1C Position Detection
System description: Kompass 001
Software number: 5N0919879
Software version: 0001
Hardware number: 5N0919879
Faults:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
Faults:
42 Driver Door
System description: Tuer-SG 009
Software number: 5K0959701D
Software version: 2149
Hardware number: 5K0959701D
Faults:
44 Steering Assistance
System description: EPS_ZFLS Kl. 74
Software number: 1K0909144J
Software version: 3001
Faults:
52 Passenger Door
Software number: 5K0959702D
Hardware number: 5K0959702D
Faults:
56 Radio
System description: Radio
Software number: -----------
Software version: 5814
Hardware number: -----------
Hardware version: ---
Faults:
19 Gateway
System description: J533 Gateway
Software number: 7N0907530AK
Software version: 1642
Hardware number: 7N0907530AK
Hardware version: H57
Faults:
02649 - Digital radio tuner
static
Code:
Date: 2023-09-07 17:24:43 (date exported)
Car:
Year: 2011
Mileage: 209280 km
Full scan
Control Units: 15
Fault count: 21
Control Units:
16 Steering Column
Faults:
17 Dashboard
Faults:
25 Immobilizer
Faults:
42 Driver Door
Faults:
Faults:
52 Passenger Door
Faults:
01 Engine
Faults:
P192700 - Auxiliary engine coolant pump relay
Open circuit
static
P069100 - Cooling Fan 1 Control Circuit Low
Intermittent
U042900 - Invalid Data Received From Steering Column Control Module
Intermittent
P157000 - Engine Control Module (ECM) disabled
Intermittent
U000200 - High Speed CAN Communication Bus
Performance
Intermittent
56 Radio
Faults:
00856 - Antenna, on radio
Intermittent
01305 - Databus Infotainment
Intermittent
Faults:
00834 - Signal for heated rear window activation
Intermittent
03396 - Supply voltage terminal 30 for central locking
Intermittent
03266 - Activation relay for signal horn
Intermittent
01259 - Fuel pump relay
Intermittent
01598 - Drive battery voltage
Intermittent
00927 - Terminal 30 right
Intermittent
03 Brakes
Faults:
01314 - Engine control module (ECM)
Intermittent
02 Transmission
Faults:
P185000 - Databus drivetrain
Missing Message from Engine CM
Intermittent
01196 - Engine/gearbox - data bus
Intermittent
Faults:
Intermittent
19 Gateway
Faults:
Intermittent
static
15 Airbag
Faults:
B10B400 - Function restriction of seat occupied recognition
due to undervoltage
Intermittent
08 Air Conditioning
Faults:
U111100 - Function limitation due to missing message
Intermittent
