Hey forum users! First off: omg love this forum and all its knowledge!
Aright, so i installed this in my 2013 golf 1,4 tsi 140 bhp yesterday. And, of course, because of my ever-existing bad luck whenever i so much as THINK about something with my car thats not off the line standard, it's not gone as i've hoped. Heres a quick rundown of the issue:
I have no sound. The amp is not lighting up. However, if i turn ignition on or start the car, and THEN run to the boot- and unplug and plug in the wire connector from the amp (white,many pins) everything works perfectly. Wtf?? My part number is 000 051 419 B. In the car is a stock discover pro with mib1. Not retrofitted.
At first i was almost sure i messed up the wiring, so i redid to stock, tested again. Sound ok. Then i triple checked both instructions and the YT videos posted here, only to confirm i had been a good little boy following instructions. Problem still persists.
I've seen another post on here with one guy with the same problem, although his Discover pro MIB1 was retrofitted to a car which had composition media.
Ive mailed Audiotech Fischer, to see what they come up with.
I've also been informed by the parts store in my local VW dealer that after asking support, they have been given the task of contacting me and setting up an appointment for guided fault searching, because the part IS supposed to fit my car.
Any ideas, tips or hints will be greatly appreciated.
Best regards,
Morten Lie
Edit: found the post with similar problem:
https://www.golfmk7.com/forums/showthread.php?t=37974&page=3 he has clearly solved ot by bying an incredibly expensive amp. I asked audiotech if they would let me borrow one to test.
