breaking badly
Banned
- St. Olaf
The stock DP isn't that 'awful' design as some think. Its cat (two cats in NA) is (are) restrictive,
not its 'inlet' or 'ellbow'.
Be assured Volkswagen used the most advanced methods including CFD to design it this way.
Be assured they tested it extensively. Contrarily most if not all aftermarket DPs are just designed
'big'. Sadly most aftermaket DPs even lack a heat shield. Remember there's the ABS/ESC hydro
block near the DP's 'ellbow'!
That said, GTI, Clubsport and R DPs are different. Both Clubsport and R factory DPs come with
a cast 'inlet'/'ellbow', while the GTI and GTI Performance as well as the 1.8 TSI use a cheaper
sheet steel part instead.
GTI & GTI Performance - stamped steel, note the 'flat spot':
Golf R and GTI Clubsport - cast:
I'd bet the CS/R DP is superior in terms of flow, however it's perhaps not worth the labour to
swap a GTI DP for a CS one (considered there are no cheap/used ones available in the US any-
way) or the R's. However it may be worth it for those few 1.8 TSI owners in Europe to fit a used
Clubsport DP.
On a side note: My very first picture is showing the revised Euro spec 7.5/facelift GTI Performance
engine (engine code DLBA) and that one obviously also gets the cast DP now!
Clubsport DP.
