The rear springs seem to be the same
5Q0511115EP.... But apparently there is 2 different front springs??? Has anyone noted this before?
There is a "
Golf R; Manual Trans. W/R, w/1 white, 1 red & 1 violet mark, w/1 white, 1 red & 1 violet mark."
5Q0411105JF
And another: "Golf R.
Golf R; Auto Trans.
GTI; Manual Trans. Suspension range 35. W/R, w/1 white, 1 red & 1 blue mark, w/1 white, 1 red & 1 blue mark."
5Q0411105JG
The fact they note having different markings makes me believe they are actually 2 different specs? The DSG is like ~50lb more...
I searched a bit, cant find anyone else having made this observation? Also the Golf R "Auto" version (which you would think would be the stronger spring) is the spring used on the GTI Manual??
But to answer your question OP, I couldnt find any differentiation between DCC and non-DCC springs, from the parts list... just this weird thing with the Auto v. Manual...
edit: checked other years, bc those links are for the 2016, and they also have different part numbers for Auto v. Manual....
edit2: OK, so it seems that this has been noted before:
https://www.golfmk7.com/forums/index.php?threads/oem-gti-springs-length.335733/
here as well:
https://www.golfmk7.com/forums/index.php?threads/mk7-golf-r-dcc-vs-non-dcc-springs.407241/
