FS: 034 Strut Mounts (front and rear)
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
flipflp
PNW
'16 Golf R DSG
I would do a search on these here. Some are good and some bad.
I've just decided to stick to OEM.
Not saying you're making a mistake, the OEM stuff works, but have you actually seen reviews of the rear HD mounts? I've only seen reviews of the front mounts and they are mixed. I have a set of the rears incoming now, just interested to see what you've read, since I couldn't find anything.
are there reviews anywhere?
I said few, but I should have said I know of no one stating they have installed the new 034 rear mounts. Had they been available I would have used when my front 034 Mounts were installed. I think rears are low risk as rear suspension has less use. I like the front 034 Mounts and would likely like the rear.
I would like to try the very new front mounts but need to check how angle change affects DD and tire wear. I had hoped the new 034 mount would have used a different end mount bearing.
afman916
Raleigh, NC
Was just looking at the rears yesterday actually and wondering if they're worth the pick up...had planned on doing front when I install my Koni Yellows this spring, but this is the first I had really heard of mixed reviews on the 034 fronts.
Can someone clue me in as to the issues people have been having? Noisy?
flipflp
PNW
'16 Golf R DSG
Not to completely hijack this FS thread, but to clarify my statement about mixed reviews: http://www.golfmk7.com/forums/showthread.php?t=37532
I'd say over 90% of suspension installs that result in squeaks were probably not installed completely correct, especially in regards to tightening and assembling the front shock/spring/mount. BUT, there does seem to be a % of mounts that just make noise.
I had 034s on my last car (2012 CC) and they squeaked paired with ST coilovers. The OEM mounts I used on a different setup were quiet.
I currently have ECS HD mounts on my MK7, and only the driver side squeaks when cold, between 45-65 degrees, until the car warms up and then it's quiet.
I don't want to damn all 034 (or HD/non-OEM) mounts but it could be a "your mileage may vary" part.
yirayira
Chicago, IL
2015 GTI SE
I’ve had the 034 rear mounts installed for about a month now, but SuperPro trailing arm bushes went in at the same time. So while I can’t give an objective review I can say I’m finally happy with the rear end
Navi
BK/NYC/Hamptons
I would agree with this. A lot of it comes down to user installation. I know this from installing and removing my suspension a couple times. Not replacing some one time bolts led to a squeak, and not torquing a couple things to spec led to noise as well. I have the 034 mounts and they made noise until I double checked everything and replaced some bolts that shouldn't have been reused.
GTI Dude 11
tennessee
gti
I will take them, can you pm me your PayPal info please.
I had the entire street density line on my b5 and loved everything about them.
