panos_lympe
- Greece
- Golf 7 1.6 TDI
Hi team, as the title says i have this issue.
I have found on another forum a similar post from 2015 but it didn't answer my questions.
So i went to the mechanic and he said its the "heat temperature flap actuator" and he asked me 250 euros for the fix (that i can't afford at the moment) so I thought i could make an attempt to fix it myself. (also this component is for the car to choose from cold/hot air - wtf). also when I asked him to show me the VCDS error he refused to do so. furthermore he told me he has to pull the whole dash for the fix, but as google guides me, it doesn't has to be this way. (I don't like anyone to touch my car for such a simple issue)
I searched all over the internet and I came across a fellow golfer in youtube that goes with the name "golfwagen". he has tutorials for everything.
I have so many questions. the old post in this forum said that he solved it by going to the dealership and replacing the blower motor. (i mean if the blower motor works, why it has to be replaced in the first place, all it does is blow, not distibuting air to specific areas).
the issue is that air isn't being distributed to footwell (floor), but when i press the footwell button, air blows to the dash instead. (even if dash button is off)
how you guys you think i should proceed? in general i think the fix is easy if i find the problem and the correct component to replace. can someone help me?
thanks in advance, cheers.
~Panos
*sorry for my non-perfect english
** i drive the mk7 1.6 TDI (2016)
~Panos
