chodeman07
- Virginia Beach, VA
Hey all,
Today I tried to do a 0-60mph pull and around 50 which was probably recline in 2nd, the car lost all power. Pulled over after 30 secondsand shut down. Checked for smoke out of the exhaust and the engine bay, nothing. Had EPC and check engine light on. When I started the car again, nothing was wrong.
The car had misfires on 1,3,4 cylinders and p0130a code for "hidden cylinder". Once again, running eurodyne stage 2 93 octane with revo high flow intake, downpipe, spulen turbo muffler delete and GFB dv+.
I emailed eurodyne regarding this to find out some stuff, but I'll ask here too as they're probably not working on the weekend before July 4th (I know they're a Canadian company) ;-)
-should I do what apr recommends for their stage 2 and use denso .024 ihk24 spark plugs?
+if I should change plugs, is daily driving like a normal person bad? I haven't had any issues in the other 2 weeks I've driven it, and driven it hard. This was just the first 0-60 launch control I've done. Also, I have not enabled the 2 step or whatever.
-Clearing the codes- is that bad because I already did that....
-I came from subaru where misfire usually indicates your engine is about to blow up. Did I fudge up my car royally? It's driving normally again.
Thanks for any help you can provide.
Nick
Sent from my SM-G930V using Tapatalk
Nick
