SeanGunn007
I see zero contradiction.
Pushing the button to turn on sport driving mode the first time "helps out" by also switching the transmission to S.
I want you to consider how the shifter behaves outside of pressing the driving mode button. Let's say you have driving mode in "normal" or "comfort", and you turn on the car and shift into drive. The transmission is in D, right?
Then you pull back the shifter and release it. The driving mode is still in "comfort" or "normal"--that hasn't changed--but now the transmission is in S.
The transmission setting is completely independent of the driver mode setting, with one small exception: the first time you move it out of comfort or normal and into Sport, it "helps" you by also moving the transmission into S.
But that is an anomaly, a thing that happens ONLY under that specific circumstance. Otherwise, there's no connection between "it's already in Sport driving mode" and "I just shifted it into Drive after coming out of the restaurant".
Zero contradiction.
Yes--and that's exactly what the owner's manual says, your denial of the facts notwithstanding.
You really, REALLY want it to behave in a way that it doesn't behave. That doesn't mean the way it *does* behave is "mysterious" or "contradictory".
The world is what it is in this matter. Accept it. Do not continue to overthink it or deny it.
Jesus, man, I was looking for an explanation of what was happening so I'm clear on how it works. I don't know a lot about how transmissions work (obviously), which is why I posted the question to this forum. I was under the impression the members help each other out if they are stuck on something and have questions.
I specifically said this is my second MK7 and my last one behaved the same way so I assumed there wasn't something wrong.
I appreciate your explanation, but your attitude sucks. You answered my question then went on to tell me how I'm trying to make my car work as if I'm a child. I'm trying to UNDERSTAND how my car works.
I was simply wondering why the trans seemed to go back into drive when it was in Sport mode. I now understand that the Sport mode selection holds all of the sport mode characteristics EXCEPT the transmission.
And for what it's worth, the manual says the trans "may return to Drive"... That's not clear. It should say that the trans "will return to Drive." That wasn't an attack on you, even though it seems you took it that way. I'm assuming you didn't write the manual.
I'm not going to waste my time looking, but I'm guessing that the manual doesn't say that the headlights "may" turn on when you engage the switch or that the window "may" roll down when you press the switch.
I hope you have a job that doesnt involve dealing with people.
