I believe you can disable or stop this beeping.
1). Turn off ignition
2). Remove key from ignition
3). Get out of car (ensuring you have your keys).
4). Close car door behind you
5). Lock your car if required.
6). Deal with the gate in your gated community.
You can kind of go back on these steps once you're done
James
Don - thats the seatbelt warning - not the door open with engine warning which is different. I have the seatbelt warning disabled (with Vagcom) but still get this beeping if a door is opened with the engine running.
I dare say there is some way to disable it - if you are good at German you may be able to figure it out by going through the Numerous Vagcom menus....
FIX THE GATE! Do you need money?
If head lights go out, will you only drive in daytime? No you will fit them.
Fix the gate.
Fix the gate.
Damn it. But they are electronic. They only muffle anoying sounds lolNot road legal.
