Edvardasast
- Lithuania
Engineering menu also can be enabled with OBDeleven that is much cheaper than VCP.
https://www.youtube.com/watch?v=GLvvHRVmWnc
Hi ChilloutMy discoveries of undocumented/previously unknown features so far:
- WLAN is on same chip as bluetooth and is available in all Discover Pro devices.
- Screenshots can be made by pushing the right twist-knob
- Overlay view of screen elements can be enabled by pushing and holding CAR button
- Developer menu can be enabled through Adaptation.
- Developer menu can be opened by holding MENU for ~20 seconds
- Overlay view of screen data/names can be enabled by pushing and holding TRAFFIC button
- Skin can be changed through Debug options in Developer menu
- Loudness can be disabled through the Green menu in the Developer menu
- Mirrorlink button in main menu can be enabled through Debug options in Developer menu
- WLAN is available after enabling Phone NAD bit in long coding(which enabled Premium Phone)
- DLNA is available after enabling WLAN (this is port 49152)
- Wlan packets can be sniffed and saved to SD through the Green menu in the Developer menu
I see the test mode menu but I haven't the menus like the last two imagesI forgot to update you guys on this...
I made an album with all screenshots I took from the green menu.
http://imgur.com/a/Y4vAo
Here's a selection from the album:
Next up: trying to set it in a mode other than "production", hopefully this might give us more menus and settings to access.
The skin change only has to do with the carbon/non carbon skin/texture in the menu's of the Discover Pro.
how is it possible ?
You need to buy it in the dealer maybe 300 usd and need to be coded with Odis onlinedou you know where can i find the activation code, activation number and activation PIN of a discover pro?
Enviado desde mi Z5 Premium E6853 mediante Tapatalk
Bringing this one back. Was there ever any progress made getting MirrorLink on the MIB1 units?
No success
There's a lot inside the MIB1 unit that says it could work, but the essential things are missing.
